I need to find out where to upload files in directory /local/floorplan/
Where is that located?
/local is the same as /www when looking in your config folder. If you don’t have a folder name ‘www’ in the config folder, then just create one. Then, create your floorplan folder, so the path will be /config/www/floorplan.
I know that’s a little weird and confusing, but this is the way. Again, /local is the same as /www.
