One super important tip I learned is to make sure ALL IDs are lowercase. pretty much make sure all device names in HASS and floorplan are lowercase to avoid a ton of troubleshooting and frustration.
floorplan.yaml (548 Bytes)
I have done as you indicated but the floor plan does not display.
- In floorplan.yaml should the path “/local” remain /local/custom_ui/floorplan/floorplan.svg.
- I have included below the floorplan.yaml to check if this is correct. The floorplan.yaml and floorplan.svg have been edited to only contain the ID “binary_sensor.front_hallway”.
floorplan.yaml
name: Demo Floorplan
image: /local/custom_ui/floorplan/floorplan.svg
stylesheet: /local/custom_ui/floorplan/floorplan.css
groups:
- name: Binary sensors
entities:
- binary_sensor.front_hallway
states:
- state: 'off'
class: 'info-background'
- state: 'on'
class: 'warning-background'
state_transitions:
- name: On to off
from_state: 'on'
to_state: 'off'
duration: 10
That’s what I have, “local” is replaced by HA with “www” … this is my floorplan.yaml …
last_motion_entity: sensor.template_last_motion
last_motion_class: last-motion
groups:
- name: Sensors
entities:
- sensor.avglroomtemp
Remember tho’ the actual files must be in /home/homeassistant/.homeassistant/www/custom_ui/floorplan/ ie where the github specifies
I have the same paths as you and @keithh666
Have you mentioned your version of Home Assistant? I think you should have > 0.42
Other than that, I cannot point you in any direction. I have very little knowledge of software development. Sorry!
I’m not sure what the difference between safari and chrome are but it works on chrome.
I have downloaded Chrome and it works now. It does not work however when using Safari.
Thank you to everyone who have assisted and guided me to getting it to work.
Many, many thanks! It is starting to look like something!
Made a few small changes, and not everything is to my liking yet, but all seems to be working!
No worries glad you got it working, it’s an awesome addition to HA
Would you mind posting your SVG or AI file? Love your image, I use AI as well would be great to use as a template.
I used this SVG file Floorplan for Home Assistant
When I’m done I do plan to share all the CSS and SVG.
Hi Bram,
I would really like the css and sgv if you are done… (mainly the css for the colors
Question, can I also use attributes as the class_template and text_template? Or only the state?
I tried:
entity.attributes.current_temperature
But that doesn’t work… what am I doing wrong?
Thanks so much for all the effort!
Is there a way to make it so that when i click on an open area of a room it switches to a room view. Been reading but i’m not really seeing any mention of it.
I made something like what i mean before with a couple other programs. Here is an example of what i mean
I use this:
https://github.com/CCOSTAN/Home-AssistantConfig/blob/master/floorplan.yaml#L7-L11
To get this:
Thanks! Got it!
Hi there,
From what I understand, you’re thinking of a set of tabs within the floorplan state card? When I get some time, I will look into how that could be done.
As an alternative, I know at least one other person who has several floorplans in his setup, as he wanted to shows all 3 floors/areas of his house. He ended up creating a separate floorplan state card for each. Not sure if he put them within the same view group (i.e. tab) or whether they appear as separate tabs in HA.
Yea I was hoping to for example click an empty area in my office from the overview and then get taken to a different view of just that room.
I’m using floorplan as a panel, not a state card, don’t know if that makes a difference. What I would like is the same structure as the states panel. I don’t know if you can reuse the tabs from the states panel?
Like this:
Did you find out why the line thickness was different? Mine is getting so thick lines, I can barely see my icons and stuff. Theyr’e just rendering like a big mess. When I open my svg directly this doesn’t happen.
It was something to do with scale vs line thinkness tags against the path in the svg xml.
I think that Inkscape and chrome don’t render svg the same.
