Floorplan for Home Assistant
@aidbish, I’m not using the custom weather component, my icons are tied to the Dark Sky component.
I saw there was another, more recent commit after I pulled the version that I’ve had problems with. It works OK now. Thanks a lot!
OK I did not have this under frontend:
extra_html_url:
- /local/custom_ui/state-card-floorplan.html
I have added that and it is now working!
Not sure if this has been posted already (can’t find anything via the search function), but I am one of those people who run multiple panels and to make it work I made the following changes to the panel/Floorplan.html, which I in turn have renamed bottenvaning.html and ovanvaning.html:
On line 3 and 38 I changed ha-panel-floorplan to ha-panel-ovanvaning and ha-panel-bottenvaning.
On line 37 and 75 I renamed the class from HaPanelFloorplan to HaPanelOvanvaning and HaPanelBottennvaning respectively.
This seems to work for me.
I want to add that it does work in Chrome, but in my kiosk browser I am getting an error relating to the renamed class and the frontend custom javascript. I can’t see it in my log anymore I’m afraid :-/
Im getting the same es5 error on both ios and my kiosk browser. If i force latest javascript, it comes up with a different script error.
For the most part, it seems to be fine on Chrome.
I am getting this error every few minutes, although everything seems to be working fine.
Error communicating with socket, resetting connection
12:43 PM /usr/lib/python3.6/site-packages/pychromecast/socket_client.py (WARNING)
Theres not even a pychromecast folder there, athough thats possibly the problem.
I can confirm, upgrading to Floorplan v1.0.13 and javascript_version: latest worked for me on Hassbian, HASS v0.70.1
I have the exact same problem, dark sky component using the svg icons aren’t working anymore in Floorplan.
What I find strange is that, if you insert them directly into the SVG floorplan they work just fine but won’t show up in the box…
For those that the floor plan don’t working on iOS , Try my solution https://community.home-assistant.io/t/having-issue-with-floorplan-on-ios/25314/14?u=virtuall
Hi All. I’m running Floorplan 1.0.13 and HASSIO 70.1, but Floorplan won’t render in my browser (Chrome). The only errors I see are:
http://hassio.local:8123/local/custom_ui/floorplan/ha-floorplan.html:86:47 Uncaught TypeError: Cannot read property ‘EventsMixin’ of undefined
1:44 PM components/system_log/init.py (ERROR)
Uncaught (in promise) DOMException: Only secure origins are allowed (see: https://goo.gl/Y0ZkNV).
(anonymous) @ floorplan:1
load (async)
I don’t think the DOMExcpetion is the problem as I get the following error when I load regular HA in my browser and it renders just fine:
(anonymous) @ states:1
load (async)
I’ve cleared my browser cache multiple times and that doesn’t fix the problem — i just get a blank screen when I click on Floorplan.
Can somebody help me out with the EventsMixin error?
Thanks!
Does anyone know if it is possible to disable the more-info behaviour when clicking on an element? Either on the floorplan as a whole or on an individual element level?
Does it not work to set action in floorplan.yaml to the entity?
After updating to HA 0.71.0, I now get a error pop-up that says “I don’t know how to resolve panel custom”.
Is anyone else getting that error, or know how to resolve?
Guys, I’m having this issue:
Uncaught RangeError: Maximum call stack size exceeded
URL: https://myaddress.duckdns.org/local/custom_ui/floorplan/lib/jquery-3.2.1.min.js
Line: 2, column: 22736
Error: {}
Perfect - thank you very much!
Yes I just updated hoping to fix the issue and the problem has converted to this error message.
I’m also getting the message “I don’t know how to resolve panel hassio” when I click on hassio on the left hand side. In fact I am getting that error for all the options map, history etc.
EDIT: Found another thread that suggested trying CONTROL+F5 to clear the cache and that has worked for everything but floorplan. I now dont get an error message with floorplan just a blank white screen? I have re-downloaded the files from github and nothing…?
Same. No longer get the “I don’t know how to resolve panel custom”. error, but Floorplan just renders a blank screen. @pkozul can you help? Thanks!
I had to upgrade to the latest HA-Floorplan version to get it working since the Hassio update to v70
FYI for those having issues, these are the specific files I had to update:
/config/panels/floorplan.html
/config/www/custom_ui/state-card-floorplan.html
/config/www/custom_ui/floorplan/floorplan.css (and re-add my previous additions)
/config/www/custom_ui/floorplan/ha-floorplan.html
HA-Floorplan works fine in Chrome on my PC, and Chrome on my Android 7 tablet.
However it no longer works at all in “Fully Kiosk Browser” which is the app I normally run on the wall mounted tablet. It just displays a blank page… no errors.
Is anyone else having issues with HA-Floorplan in Fully Kiosk Browser (but not Crome) since the update ?
I have cleared browser cache multiple times, and rebooted hassio.
When you said you had to update floorplan.html, where did you get the new file from? I only see an update from @pkozul for ha-floorplan.html
