Floorplan not fitting in screen without scrolling
Just finished setting up my floorplan for the 2nd story of my home. When i flip it into panel mode it gets so large that it requires scrolling down to see everything, heres an example of what i mean
Any help with this would be greatly appreciated.
Are you using panel: true? If so, you may want to adjust the aspect ratio of your base image to be more widescreen if you plan on viewing it on a widescreen monitor
I adjusted the image and tried making it smaller but still no luck it doesnt matter if it’s displayed on my 1440p or 1080p monitor. Once panel true is turned on it just makes it huge.
Making it smaller won’t work, you need to adjust the aspect ratio. I.e if the image is 4:3 you need to make it 4:2.5
Ahh ok. well crap that’s probably gonna mean that I have to redo all of the images.
well, you could just add blank space to the left and right of your current image. Then you’d just need to adjust the position of items. I recommend gimp, it’s like photoshop but open source.
Get a smaller house. Sorry, somebody had to say it.
Lol that was good
i fixed the issue just had to make the image shorter and remember to clear the cache
