OOOkey, so delete step 3 and give to my circle the id!
I’ll let you know soon!
Simon
Simon
@Oscar When you try the new version of Floorplan, just keep in mind the 100% height behaviour will work when your Lovelace view is set to panel mode, and that view only contains a single card, which is Floorplan card.
For example, this is how mine is set up:
- title: Floorplan
path: floorplan
icon: 'hass:floor-plan'
panel: true
badges: []
cards:
- type: 'custom:floorplan-card'
title: Floorplan
config: /local/floorplan/examples/home/home.yaml
Hello again @pkozul ,
Also, now it works as expected! Yuppie!
Only one thing is not working, your example about action, but as you’ve written, I need to update to version 1.0.8, so I’ll wait until @exetico gives me some hints on how update. With my code I can see the bulb where it should be, and it works. With your example, the bulb is missing and if I press on the circle, which should be replaced with the bulb, I obtain the popup window of the entity, and not the action turning the light on or off.
For now, thanks for the fast support!
Simon
@xefil One way to get Floorplan directly, is simply to save the floorplan.js
file to the relevant folder where you’d like to store it.
Right-click this link below, and choose ‘Save link as…’
https://raw.githubusercontent.com/ExperienceLovelace/ha-floorplan/master/dist/floorplan.js
I store mine in the {HOME_ASSISTANT}/www/floorplan
folder, and then create the Lovelace resource for it.
/local/floorplan/floorplan.js?v=1.0.8
The great thing about this new version is that everything is in this single file.
Hello @pkozul , ok, wait I fear I’m bit confused.
Under HACS I have as repo “https://github.com/ExperienceLovelace/lovelace-floorplan” and you are pointing me to a raw file into repo “https://github.com/ExperienceLovelace/ha-floorplan”.
Is this the way you switch between master and test? Using different repos instead of braches?
Do you suggest to delete in HACS the lovelace-floorplan and use the ha-floorplan instead?
Or leave the HACS with the lovelace-floorplan and use this as manual setup? So they could be used together, it dipends on the resource called… but I’m not sure on what I’m writing
Thanks!
Simon
I’m sorry for the mess. I implemented the HACS support for the old version (lovelace-floorplan
), but the new version are almost ready. @pkozul have pushed the fix to the new version (where the codebase are completly rewritten, and includes new features, too.).
So, plese remove the old repo from HACS, and replace it with with custom repo:
We’re waiting for it to be added in the main HACS repo. The PR is submitted #751.
Also, you must be using the old action
trigger. It should be replaced with on_click
Until we get the docs completed, the best reference is to see the examples:
On the left navigation menu, you can choose between 3 examples:
And for each example, you can see the Floorplan in action, as well as view the YAML and CSS being used.
Thanks @pkozul and @exetico , repo deleted and added the other one, all works perfectly!
Downside: my files were stored into the old www path, and removing the repo and uninstalaling it, they were deleted, but not so bad, I have a copy on my pc.
Now your code @pkozul works.
Next steps, test motion sensor and the way an area gets colored on motion. hope I’ll able to accomplish it easy
Simon
PS: devel mode recognized Floorplan for Home Assistant (ha-floorplan)Version 1.0.9
That’s great to hear! I just edited my post, cause it was a bit unclear, to be honest.
The first “public” / non-pre release will be ready soon. Only the docs, and the submit to HACS’s default lib, are currently waiting
Let us know, if you’re facing any issues.
@pkozul are the examples based on the same SVG found here?
I would try following what happens on bedroom, that should be the case I could follow for my binary_sensor.sensore_motion01
Thanks, Simon
The example files can be found here:
Thanks a lot!!
And you might even like to use the on / off light bulb SVGs we have in the Home example
Thanks for your help but I have not much time and I am facing some problems that does not allow me to get the floorplan visible
I will wait till the final release and documentation is ready to try it again without bothering you
Hi Oscar
ha-floorplan will not see any changes in the structure, so fell free to give it another try. If you’re facing any issues, please share your current configs including whatever else needed.
I’ve merged my own setup, and that’s working just fine, after changing the most primary ‘keys’:
Since the old floorplan I did not update anything so, I am sure that I am missing something in the configuration, not an issue in your implementation for sure
If I had more time to check it, I probably would get it working but for me it is impossible to expend more time, sorry. Anyway, thanks for your support and your willingness to help the community, I really appreciate it
Hope after holidays I will be able to find more time to check it, though the official release will be available.
Thanks again for your work
at https://github.com/ExperienceLovelace/lovelace-floorplan it says:
Just add the URI to HACS’s as custom repository.
but i get a Invalid Add-on repository! so what is the URI to use?
Hi.
It’s currently a bit of a mess, while we’re moving to the new repo.
Please see:
Also, take a look at examples (use left-side menu), or the buttons in the bottom of the page:
i tried with https://github.com/ExperienceLovelace/ha-floorplan
that did not work either
So i guess i have to wait
Well, it’s working just fine here. See screenshots below.
Select Lovelace
as the category while adding it as a custom repo. I’ve just tested it again, and it’s working just fine
(We’ve already submitted the PR to HACS, but waiting for them to handle the request. It’s totally ready to be used as a custom repo already)
