Hi guys,
I’m having issues with my 3d floorplan showing very small and hard to use I’ve used sweet home 3D and then inkscape to
Setup image but only shows ok on PC but still not perfect on phone in either verictal or horizontal views still not correct shame there’s no zoom option.
Is there a Best size resolution for image b4 importing into hass.
Also I’ve been trying to getaway from side menu Floorplan button and add tab buttons like you do in groups.yaml but I cant work it out I’m possibly thinking my floor plan is to big to fit on one screen arrrrrr
Anyhow I’ll provide a link to a video showing my floor plan has.
CCTV x 5cams
Emergency lights
Bug zappers
Pir security sensors showing movement as red
And touch lighting
https://photos.app.goo.gl/yAH41WirC142zt7V6
Big enough to not look pixelated on the highest resolution screen you expect to use.
Are you using panel view or a card on the floorplan tab?
https://www.home-assistant.io/lovelace/views/#panel-mode
Even with panel mode enabled on my floorplan views the flooplan is way too small on my phone. The only way around this that I can think of is splitting the floorplan up into rooms. Maybe one simple floorplan to be used as a menu which calls pop-up cards for the rooms. Not sure it’s worth the effort.
Hi thanks for the reply I’m not that familiar with the Lovelace thing I’ve just avoided using it lol as I’ve had issues with it in the past I guess I need to learn it to move forwards, I’m not sure the difference between panel view and card view I just used the downloadable version from GitHub and then made some basic changes to configuration.yaml . I attempted to add a tab for floor plan by adding group view in group.yaml it does shows but also shows list of entities asosiated with floorplan lol
I’m fairly sure what I did was not the correct way.
I guess I’ll investigate love lace I’m not sure how I merge my existing config / downloaded version from GitHub into Lovelace or do I start from scratch.
Thanks so much
