Floorplan SVG images for On/Off not aligned
Hi all, sorry but I’m a bit newbee. I’ve tried almost everything and double checked SVG format, size, position, etc, but I’m not able to center rooms on the floorplan. They are unscaled and moved to the right upper corner. Any ideas? here you are the code
    - badges: []
    cards:
      - config:
          image: /local/floorplan/planta_baja.svg?v=1.1.15
          log_level: error
          more_info: true
          rules:
           - action:
              service: homeassistant.toggle
             element: light.terraza
             entity: light.terraza
             image_template: '/local/floorplan/terraza_${entity.state}.svg'
             state: image
           - action:
             element: light.salon
             entity: light.salon
             image_template: '/local/floorplan/salon_${entity.state}.svg'
             state: image
           - action:
             element: light.cocina
             entity: light.cocina
             image_template: '/local/floorplan/cocina_${entity.state}.svg'
             state: image
           - action:
             element: light.estudio
             entity: light.estudio
             image_template: '/local/floorplan/estudio_${entity.state}.svg'
             state: image
        type: 'custom:floorplan-card'
        # title: Planta Baja
    icon: 'mdi:floor-plan'
    panel: true
    path: Planta Baja
Your code is correct, you have to align correctly on Inkscape, I had the same issue.
