Flow control on esphome, PID?
Hi all,
I have an configured and esphome with a flow sensor and a servo, this to control a flow in a pool system.
Manually I can read and change the servo to the correct flow speed. But I want to automate that.
The flow should be 0.95L/min and the servo setting goes from 0 to 100. At the moment manually at 48.
I think I need some sort of PID control to automate it, but the climate PID expects a temperature sensor…
Any idea’s on how to achieve it on the esp ?
A different PID plugin ported from Arduino? Or ?
Any help is appreciated, I am not a coder…
Can you not just calibrate the servo so that you know what percentage on the servo equates to 0.95L/s?
That would work, the only problem is the water coming in differs sometime in flow. Due to filter getting full or a speed change of the pump. So that why I am looking for some automatic… Now I manually change
the setting daily.
Well that is not automatic enough! I guess when flow is low, increase by 10%, if high decrease by 10%. Try that, it may do the trick.
The other way would be to try faking it, create a template sensor which takes the flow, and forces it to be a temperature. And similarly for the servo.
That is indeed an idea, change it to temperature. :slight_smile: Will try that, and see how that goes.
And for the other option, increase / decrease. How would you program that? In the esphome firmware ? Or with an automation in Home Assistant ?
On the esp with a bit of lambda code.
Hmmm, could I ask for an example? I think you have more experience with coding than I have now, more of an hardware guy…
Will start reading!
may I ask the model number of flow meter that you’re using?
I am using a Sea YF-S201 from Amazon.de
Flow Sensor
