I downloaded home assistant source code of backend from github.
I added some prints and logs in main , bootstrap and core in order to debug the code.
All the prints added in main are visible on console when I run the following command:
python3 main --open-ui
But I am unable to receive the prints added in the other files. Also I even removed core.py but still the home assistant web ui gets opened.
Can you please tell me why I cannot add print statements in these files…From where it is executing core.py if I removed it from the source code folder…How can I debug and understand the flow of this source code?
Intsalled pycallgraph and tried executing a script using this module. Getting this error:
File "/home/ayushi/.local/bin/pycallgraph", line 25, in <module>
with __pycallgraph.PyCallGraph(config=__config):
File "/home/ayushi/.local/lib/python3.5/site-packages/pycallgraph/pycallgraph.py", line 32, in __init__
self.reset()
File "/home/ayushi/.local/lib/python3.5/site-packages/pycallgraph/pycallgraph.py", line 53, in reset
self.prepare_output(output)
File "/home/ayushi/.local/lib/python3.5/site-packages/pycallgraph/pycallgraph.py", line 97, in prepare_output
output.sanity_check()
File "/home/ayushi/.local/lib/python3.5/site-packages/pycallgraph/output/graphviz.py", line 63, in sanity_check
self.ensure_binary(self.tool)
File "/home/ayushi/.local/lib/python3.5/site-packages/pycallgraph/output/output.py", line 97, in ensure_binary
'The command "{}" is required to be in your path.'.format(cmd))
pycallgraph.exceptions.PyCallGraphException: The command "dot" is required to be in your path.
