Flower watering
Flower watering
How can I ensure that the code (ESPHOME) continues to run even if no WIFI is available?
esphome:
  friendly_name: hydrophonic
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: VERBOSE
# Enable Home Assistant API
api:
  encryption:
    key: "5GgSOc0S41Xob6Ps3NbCCF9wi2m9eQW3gtLAGrYqBt4="
ota:
  password: "ece47d972c7a16658b4be3675ac2b97c"
wifi:
  ssid: !secret wifi_ssid
  power_save_mode: none
  ap:
    ssid: "Testesp32 Fallback Hotspot"
    password: "v8L2uBgNOlf2"
captive_portal:
binary_sensor:
  - platform: gpio
    pin: GPIO16  # GPIO-Pin des Wasserstandsschalters
    internal: false
    filters:
      - delayed_on: 10ms
    device_class: moisture
  - platform: gpio
    pin: GPIO12  # GPIO-Pin des Relais
    internal: true
    device_class: power
switch:
  - platform: gpio
    pin: GPIO13  # GPIO-Pin des Relais
interval:
  - interval: 1min
    then:
      - if:
          condition:
            binary_sensor.is_on: water_sensor
          then:
            - switch.turn_on: relay
            - delay: 1min
            - switch.turn_off: relay
See the reboot_timeout option here: Native API Component — ESPHome You need to disable it by setting it to 0.
I think you have to do the same with the wifi timeout.
