Hello, I’m relative new to HomeAssistant (but quite enthusiastic)
Recently I bought two Sonoff TVRZB radiator valves and integrated them in Home Assistant with ZHA (SkyConnect).
One of them is working as expected, but the other is more or less changing the local temperature display.
Maybe the reason of this behavior is that I tried to calibrate the local temperature to a correct value (the initial temperature was too far of).
I did this with the GUI
But after my problems I also tried it with the ‘Set state in the developer tools.
Now I’m in a situation that the temperature offset is frequently changing (many times per minute) , between de values -0.2, -1.3 and -1.0 (2,13 and 10).
It seems that some process is sending calibrate requests frequently, but I can’t figure out what is causing this. I already tried a reboot of Home Assistant and a factory reset op the device, but that didn’t solve the problems.
A typical part of the logfile is shown below.
Can someone help give me some directions how to solve this problem?
Thanks in advance,
Jos
2024-02-01 10:59:09.890 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2340 update
2024-02-01 10:59:10.890 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -13 update
2024-02-01 10:59:10.891 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2200 update
2024-02-01 10:59:11.895 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2200 update
2024-02-01 10:59:11.896 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -13 update
2024-02-01 10:59:12.900 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2200 update
2024-02-01 10:59:12.902 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -2 update
2024-02-01 10:59:13.900 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -2 update
2024-02-01 10:59:13.901 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2200 update
2024-02-01 10:59:14.909 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -2 update
2024-02-01 10:59:14.911 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2390 update
2024-02-01 10:59:15.909 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2390 update
2024-02-01 10:59:15.910 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -2 update
2024-02-01 10:59:16.907 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2390 update
2024-02-01 10:59:16.908 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -10 update
2024-02-01 10:59:17.913 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -10 update
2024-02-01 10:59:17.915 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2210 update
2024-02-01 10:59:18.917 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -13 update
2024-02-01 10:59:18.919 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2160 update
2024-02-01 10:59:19.918 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature_calibration' = -13 update
2024-02-01 10:59:19.920 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.trv_mbr_thermostaat: Attribute 'local_temperature' = 2160 update
