I have an Astralpool Eco Elyo Heat Pump. The HACS install didn’t work, however I managed to perform manual installation. I’ve opened an issue regarding this on github.
Any way, I cannot access the heat pump controls, pressing the “pump” switch does not turn it on, it turns itself off after a second. Also turning the heat pump on via the Fluidra APP, does not turn the switch on on Homeassistant.
Also still no modes or temperature visible. Only the firmware version and IP visible.
I’ve added some climate entities for testing, but because I don’t have your device, I can’t reverse-engineer it. That will make it difficult to find the correct commands. Try giving me some logs so I can take a look
I got your integration setup, authentication with Fluidra Cloud seems to be working fine but the projector doesn’t appear. I tried to activate debug log but I don’t see anything in logs concerning the Fluidra Pool integration so I can’t create the issue on Github as you recommend.
Could you please give me further advice so we can get Fluidra Pool compatible projectors working in HA ?
Qq, instead of the values inside the fluidra app that you can change for ORP amd PH, it seems that these just copy the current value, rather than change the setting.
Is this a little bug at the moment?
