Flume Water Meter Units
My flume water meter works perfectly with HA, but it reports all readings in gallons. When I login to the flume portal, readings are presented in CF, which matches the billing from my local utility. Should the integration be presenting CF as well, or is there an option I’m missing to change it? I didn’t see anything in the docs or on the github about units or changing them. I can setup a template to take care of the calculations of course, but I thought I’d ask before heading down the wrong path potentially.
Know this been idle for a while, but there should now be Unit of Measurements within the Integration allowing you to change to CF (ft³).
One issue that is still a submitted bug is Energy Dashboard does not support CF (ft³) for a measurement. If you leave it at a supported unit of measure and add it into Energy Dashboard then change it to CF (ft³), it would work, but it will display in Energy Dashboard in the unit of measure you initially submitted it in, not the preferred CF.
If this is a problem for you, please help me get some more visibility on this github issue, that would be awesome.
Energy Dashboard Gas and Water supported units of measure limitation (CCF and others) · Issue #15038 · home-assistant/frontend (github.com)
