I have a FLUME water monitor. The integration was initially working until I moved home assistant to a new VLAN with new IP. This required me to also re-associate the FLUME bridge with the new IP range and for reasons that are beyond me this broke the relationship with home assistant. So I am deleting the integration, home assistant “discovers” it and when I try to configure it, I keep getting an error “Failed to connect”. With a PC on the same VLAN, I am able to browse the internet and connect to FLUME’s web portal.
I even run docker logs -f homeassistant to watch for any tidbits of info there but nada. Searching on it, I find past issues from couple years back here and there.
any suggestions?
is there any command line tool I can run to verify it’s not a connection issue?
