Flux brightness
pls add some relative brightness compensation value. I use also brightness adjustment of Flux integration, it makes no sense to have it without possibility to set relative brightness or its lower and upper limit. Every room/light needs different brightness due to different brightness of bulbs and local conditions.
For instance, while living room is normally being dimmed from 30% to 80% because of several large lights installed, washroom needs to be dimmed only from 80% to 100% as lower values are not comfortable there.
So would be nice to have start and stop values for brightness like color temperature.
Also the “disable_brightness_adjust” parameter makes no sense when ignoring “brightness” parameter does the same job. I vote for saying bye to “disable_brightness_adjust” property and say hello to “sunset_brightness”, “start_brightness” and “stop_brightness”.
