Hi, I’m new to this forum. Not new to programming. I’m looking for info on the Flux Bulb code, it doesn’t seem to be available since it’s apparently in the core. I was hoping to use the Flux bulb code as a starting point to create an interface to some generic smart wifi bulbs I have. The Flux identifies my bulbs and turns the bulb off, BUT when I turn the bulb on the bulb goes into a zombie state glowing at about 10% grey sorta color and needs to be reset. Obviously the Flux API is very close to what’s needed for my bulbs but something has been changed slightly. If I could find the Flux bulb code possibly I could change it work with these bulbs and document / post it to help others. Possibly create an integration for these bulbs with open code so others could modify API to other bulbs expanding the light bulb compatibility for HA. I see lots of talk about generic light bulbs.
Is this what you are looking for? https://github.com/home-assistant/core/tree/dev/homeassistant/components/flux
