Hi, I was wondering if anyone else has the problem that flux_led lights don’t show the effect menu anymore?
It doesn’t show the effect select at all, and if I click where it should roughly be it shows up, but greyed out. Does anyone know what this might be?
Were you able to resolve this issue?
I’m experiencing the same.
I just ended up creating my own input_select with the according automation to get it working.
That works!
Hey guys, does this UI exist in Lovelace?
It does, the colourwheel just looks different. Depending on how you set up your lovelace, you might have to either click on the name of the Entity, or tap and hold on the entity-button for example, then the UI should come up
So it does. I noticed it comes up once the light is turned on. Thanks for responding, I really appreciate it. Cheers.
