Flux_LED Integration
Does anyone have any experience of integrating Magic Home (Flux_LED) with Home Assistant? I’ve been trying to add it but it’s not working. Not devices are discovered.
light:
  - platform: flux_led
    devices:
      192.168.1.201:
Please don’t post screenshots of your code, instead copy the code, mark it and then press the </> button on top to format it.
Do you get any errors in the logs? Did you try to set the lights up manually through their IP?
I have just updated the code and tried with a direct IP. No change. No errors in the logs.
Did you restart HA after changing the config?
Twice. (just to make sure)
Are you able to control the light through the MagicHome app? May be possible that your light is not supported.
Yes, I’ve been using it through the app since getting the light last year.
Sorry, I’m out of ideas and I don’t have a Flux_LED to test.
