I would like to request an adjustment to the FLUX LED integration to handle bulbs that are single color. Currently the only way to control them successfully is using the default configuration of RGBW. This allows the on/off control and brightness dimming to be controlled. However it also brings up the color wheel in the HASS control. Using the ‘w’ mode does not work, because I believe the add on tricks the white value to respond to brightness. And since there is no separate white channel it will not respond. I can provide more detail if needed.
Thank you in advance for your consideration.
Cheers!
