I can not find Flux LED / MagicHome when I search in integrations! Is the integration still active?
I have followed the instructions at Flux LED/MagicHome - Home Assistant
Check the version of HA you’re using, probably you’re running something older than 2021.11 since that was when it moved to UI setup.
Yes, I’m running an older version! Thanks!
Have not dared to update due to the Tuya upgrade …
