First off, This is a great card! Love it!! Any idea how to remove the indent on the nested entities?
Check “padding” property in docs.
Hi All,
I‘ve read the whole thread (I must admit that I didn‘t understand everything), but I didn’t find a solution to define a card-mod that applies to all entities (head and entities).
Currently I use the following code to define it for each entity separately:
type: entities
entities:
- type: custom:fold-entity-row
head:
entity: cover.alle_markisen
card_mod:
style: |
:host {
{% if is_state(config.entity,'open') %}
--paper-item-icon-color: red;
{%else%}
--paper-item-icon-color: green
{%endif%}
entities:
- entity: cover.markise_links
card_mod:
style: |
:host {
{%else%}
{%endif%}
- entity: cover.markise_mitte
card_mod:
style: |
:host {
{%else%}
{%endif%}
- entity: cover.markise_rechts
card_mod:
style: |
:host {
{%else%}
{%endif%}
Is there a way to define only one card-mod that applies to all entities (head and entities)?
main card-mod thread → 1st post → link at the bottom → f-e-r
hmm, not really fantastic, but yes, this one
well, it could be not obvious from posted examples - but here is your way:
type: entities
entities:
head:
entity: sun.sun
padding: 15
open: true
entities:
- entity: sun.sun
- entity: sun.sun
card_mod:
style: |
:host {
But what I completely missed - you need to check a state…
My fault, let me think a bit.
Check this one:
type: entities
entities:
head:
entity: input_boolean.test_boolean
padding: 15
open: true
state_color: true
entities:
- entity: input_boolean.test_boolean_2
- entity: input_boolean.test_boolean_3
card_mod:
style: |
:host {
--state-input_boolean-on-color: red;
--state-input_boolean-off-color: green;
This is an example for input_boolean, you will need to write a similar code for covers like:
:host {
--state-cover-open-color: red;
--state-cover-closed-color: green;
--state-cover-closing-color: cyan;
Thank you very much, that helped!
Now this code is working:
type: entities
entities:
head:
entities:
icon: mdi:dock-left
icon: mdi:dock-top
icon: mdi:dock-right
state_color: true
card_mod:
style: |
:host {
Can I ask another question related to this kind of code? How can I hide the state („Aus“ and „Geschlossen“)?:
show_state: false doesn’t work:
head:
entity: binary_sensor.alle_fenster
show_state: false
state_color: true
card_mod:
style: |
:host {
--state-binary_sensor-on-color: red;
--state-binary_sensor-off-color: green;
Do not invent options ).
You may try using “custom:template-entity-row” for customizing/not showing a state.
Also, you may hide a state for a standard entity row by card-mod, there should be a ready example on the link I provided above.
I didn‘t invent „show_state: false“, I‘ve found it in other posts!
Can you give me a closer hint where to find that example?
Someone did not read Docs & posted smth, another guy took it “as is” - this is how fake news are spread)).
No, cannot, sorry, follow the link I gave you, it is there…
This option may belong to many cards - & may be absent for some card, it is normal.
Now I‘ve found that one…
…and it hides the state with this code:
type: entities
entities:
- entity: binary_sensor.alle_fenster
card_mod:
style:
hui-generic-entity-row:
.text-content:not(.info) {
display: none;
But when I add „ type: custom:fold-entity-row“…
type: entities
entities:
card_mod:
style:
display: none;
… it’s back again:
How can I hide the state in this card type?
Do not have a ready example.
Go to card-mod thread → 1st post → that link
Find there examples for fold-entity-row & adapt for your needs.
I‘ve found a solution: I set the the type of the head and the entities to custom:multiple-entity-row and then can use card_mod for them:
open: true
head:
type: custom:multiple-entity-row
show_state: false
state_color: true
card_mod:
style: |
:host {
entities:
- entity: binary_sensor.fenster_gastebad_contact
show_state: false
- entity: binary_sensor.fenster_bad_contact
show_state: false
- entity: binary_sensor.fenster_schlafzimmer_contact
show_state: false
- entity: binary_sensor.fenster_lilli_contact
show_state: false
- entity: binary_sensor.fenster_marie_contact
show_state: false
I have another question: Shouldn’t child elements of a group that are group parents themselves automatically be expandable as well (without listing them as entities)?
Like with this code:
type: entities
entities:
head:
entity: light.alle_lichter
I only get this, although all of the children are group parents:
Hi, I’m trying to move everything to the left, and I have to remove the icons, why doesn’t the style work?
head:
type: section
label: Aperture
style: |
:host div#items {
margin: -100px -200px -200px -20px;
entities:
- entity: sensor.conteggio_aperture_posta_giornaliere_lettura
name: Aperture giornaliere
- entity: sensor.conteggio_aperture_posta_mensili_lettura
- entity: sensor.conteggio_aperture_posta_annuali_lettura
Firstly, left padding on this card is managed via an inbuilt setting. See the documentation for details on the padding:
key.
Secondly, it looks like you are trying to apply changes via the custom frontend component card-mod
: do you actually have it installed? And which version? Since version 3.4.0, all styles need to be under an explicit card_mod
key.
If wanting to remove the display of icons from entities for example, then you are probably better off asking this in the dedicated thread for card-mod, where you find detailed explanations and examples, especially in this excellent post by community member Ildar_Gabdullin.
