Iâve â#â the row that doesnât seem to work. What Iâm trying to do is put the slider in the header as well, but itâs not showing up. tried type without the â-â as well both compile but doesnât show slider.
You do not need the â-â. But you do need to add another row which specifies the entity for the header row (and you may wish to have the header toggle or not). Maybe you need to create a new entity which is a group or a light group called either group.bedside_lights or light.bedside_lights to use in the header.
and they also donât work. if thatâs what you mean by adding an entity type etc.
my light.master_bedroom_bedside_lamps is the group for the two individual lights in the fold down.
so when i toggle on and off for the master bedroom bedside, the lights turn on and off at the last set level. and the only way to dim them is to individually dim each of the entities.
I want to add a slider dimmer for the âlight.master_bedroom_bedside_lampsâ as well, which works if I add it as a separate card, or an extra entity underneath that folds out, but cannot work when the light.master_bedroom_bedside_lamps is part of the âheadâ
wow⊠I donât get it⊠still doesnât show up⊠I did exactly the same before and tried it again now and still nothing⊠so I have the following:
Mate, could you explain what youâre going to achieve?
It looks like you put everything in there without understanding what youâre doing.
Namely, do you understand what happens when you use group in head?
Iâve been using this entity extensively for several months now, so first thanks for making it!
Since upgrading from 105 to 106, Iâve a problem with only one of my fold entities. The top one here was working just as is without a change before I upgraded.
In case you havenât seen it there are some changes in v106 that affect custom cards (I wouldnât expect this to affect this custom card, but wanted to check since I am seeing errors).
I did install the latest version of this entity from HACS before posting here, but I also tried updating HACS and have had some issues getting my install back up and running, so Iâll have to check on it again when I get home. I did see this issues still after installing the latest version, but now Iâm not super convinced HACS actually installed the latest version, so itâs possible that will fix it.
I got HACS working, and have tried uninstalling and reinstalling fold-entity-row and slider-entity-row as well as restarting several times, but Iâm still seeing this same problem.
Iâm really not sure why this is only a problem for this one group. I have several other groups in this card that have all of the same stuff (groups, lights, slider-entity-rows) that work fine.
