thought I had it⦠adding a hui-element card_type: entities below the fold-entity-row, so I could style these entities with a left margin of -26px, so they appear almost as if they are a regular entities card. Which they did
- type: custom:fold-entity-row
head:
type: section
label: More detailed info
entities:
- type: custom:hui-element
card_type: entities
style: |
ha-card {
box-shadow: none;
margin: 0px -16px 0px -26px;
entities:
- entity: sensor.dark_sky_daily_summary
- entity: sensor.dark_sky_hourly_summary
- entity: sensor.dark_sky_temperature
- entity: sensor.dark_sky_cloud_coverage
But suddenly I noticed this error (top and bottom error, middle is for a conditional card):
now reverted to:
- type: entities
title: Darksky Currently
entities:
- entity: sensor.dark_sky_apparent_temperature
name: Apparent temperature
- entity: sensor.dark_sky_wind_speed
- entity: sensor.dark_sky_summary
- entity: sensor.dark_sky_icon
head:
type: section
entities:
which is error-free, but shows the entities in the fold-entity-row too much shifted to the right.
How can I style these entities correctly, please have a look?
Not 100% sure if this is what youāre after, but this works for me (using card-mod
style: |
:host div#items {
padding-right: 20px;
head:
almost thanks!
before:
just a bit too much to the left, using:
style: |
:host div#items {
margin: 0px 0px 0px -26px;
this seems rather spot on:
style: |
:host div#items {
margin: 0px 0px 0px -20px;
Or maybe you could just set the padding parameter of fold-entity-row to 0, but what do I know?
sounds as if weāre on to somethingā¦
how do I do that:
head:
type: section
label: Day after tomorrow
style: |
:host div {
padding: 0px;
entities:
- entity: sensor.dark_sky_forecast_icon_2d
name: Condition 2 day
- entity: sensor.dark_sky_forecast_daytime_high_temperature_2d
name: High temp 2 day
- entity: sensor.dark_sky_forecast_overnight_low_temperature_2d
name: Low temp 2 day
- entity: sensor.dark_sky_forecast_precip_intensity_2d
name: Intensity 2 day
- entity: sensor.dark_sky_forecast_precip_probability_2d
name: Probability 2 day
- entity: sensor.dark_sky_forecast_summary_2d
name: Summary 2 day
doesnāt help. Must be wrong? https://www.w3schools.com/css/css_padding.asp instructs to do so?
related:
using
head:
type: section
style: |
:host div#items {
entities:
- sensor.locatie
- sensor.rain
- sensor.humidity
works perfectly, but the same style on the above dark_sky entities doesnt:
head:
type: section
label: in 3 days
style: |
:host div#items {
margin: 0px 0px 0px -36px;
entities:
- entity: sensor.dark_sky_forecast_icon_3d
name: Condition 3 day
- entity: sensor.dark_sky_forecast_daytime_high_temperature_3d
name: High temp 3 day
- entity: sensor.dark_sky_forecast_overnight_low_temperature_3d
name: Low temp 3 day
why is that?
do I need a different div for a list of entity objects?
duh, wrong indentā¦
head:
type: section
label: in 4 days
style: |
:host div#items {
working perfectly.
still looking for the āpaddingā solution. tried the same ācorrectā indent on
style: |
:host div {
padding: 0px;
but that doesnt work, so please help me out there?
@thomasloven is referring to the padding
option in the standard available parameters for the card, that you can set without using card-mod
(see documentation ).
But as far as I can tell, this only adjusts the padding on the left hand side of the folded rows, so I use card-mod
to set the indent on the right-hand side. But hereās the code with the left padding set to 0:
padding: 0
head:
type: ...
well I beā¦
I had completely missed that. And it does exactly what I was looking for, the same as
style: |
:host div#items {
really sorry for this.
and thanks for pointing me to it.
everything beautifully aligned. Not sure what indent you want to change on the right hand side?
unfortunately, it doesnt work for an auto-entities card under the fold:
head:
type: section
label: More Waqi info
padding: 0
entities:
- type: custom:auto-entities
card:
type: entities
style: |
ha-card {
box-shadow: none;}
# margin: 0px -16px 0px -36px;
and I need the margin to be set in the style.
Is it possible to change the color and size of the font for the label?
Like this one: Could I change «Roberto» to white and same font size as the rest of the list?
My code looks like this now:
entities:
- entities:
- entity: switch.roberto_kitchen
- entity: switch.roberto_kontor
- entity: switch.roberto_sofa
- entity: switch.roberto_tv
- entity: switch.roberto_spisebord
- entity: sensor.roberto_status
icon: 'mdi:robot-vacuum-variant'
- entity: sensor.vacuum_battery
icon: 'mdi:battery'
head:
label: Roberto
type: section
theme: ios-dark-mode
type: 'custom:fold-entity-row'
type: entities
Iām looking for the same thing now. Is this possible?
To be more specific: I have a camera as a picture glance card and would like to by default have it collapsed. Perhaps thereās another solution to this. Iām keen to hear.
Great, thanks, @eggman ā Iāll check this out.
Shoomaan
(Lars)
May 17, 2020, 7:00pm
112
Good Evening,
I have a Problem with the combination of auto-entities and fold-entity-row. When trying the examples from your help file, I get no frame in the frontend. Example all groups (frame) and example automatically populated (no frame) .
Could someone explain me what I can do to change this behaviour ?
eggman
(bertie basset)
May 17, 2020, 7:03pm
113
It would help if you posted your YAML
Shoomaan
(Lars)
May 17, 2020, 8:51pm
114
card:
type: entities
title: All groups
filter:
include:
- domain: group
options:
filter:
include:
- domain: sensor
card:
head:
type: section
label: Automatically populated
That all still needs to go inside an entities card.
Shoomaan
(Lars)
May 19, 2020, 12:24pm
116
Thank you very much for this hint
Got it right the way it should be.
Niall
(Niall Scott)
May 25, 2020, 7:17pm
117
I am new to HA and I am trying to build a drop-down which is kind of working but I cant figure out dynamic labels. I want my label to say āBrightness: 108 luxā for example, I am trying to set a label using
'label: >
[[[return āBrightness: ā + sensor.living_room_lux + āLuxā]]]ā
Unfortunately, all it is outputting is the code for the label:
My code is:
- type: horizontal-stack
cards:
- type: custom:button-card
styles:
card:
- opacity: 0
- width: 25px
- height: 1px
- type: entities
style: |
ha-card {
background: none;
box-shadow: none;
border-radius: none;
entities:
head:
type: section
label: >
[[[return 'Brightness: ' + sensor.living_room_lux + 'Lux']]]
Could someone point me in the direction of where I have gone wrong?
Many thanks
Does anyone know if I can make a section open conditioned on the state of another entity, e.g.:
open: '{{ states.remote.lounge == "on" }}'
Iām open to any method to solve, all suggestions welcome.
Thanks.
There is a conditional card you can use for that⦠a core card
Thatās a good solution.
