I was looking for a nice way to interact with my Raspberry Pi to quickly reboot services or shutdown/reboot the Pi. Before Lovelace I used an input_select element to trigger the actions. Yesterday I’ve fiddled around a bit and found a nice way to archieve this with a conditional card nested in a custom:vertical-stack-in-card. It’s basically a dropdown/foldable menu triggered by an input_boolean. It looks like this:
THE STEPS REQUIRED:
1. Create an input_boolean:
input_boolean:
raspberrypi_menu:
initial: off
icon: mdi:menu-down-outline
2. Create a shell_command e.g. to shutdown the Pi:
shell_command:
raspi_reboot: sudo shutdown -r now
3. Create a script to run the shell_command. For some reasons shell_commands cannot be run directly by ui-elements. So the script is a little workaround
script:
raspi_reboot:
alias: Pi Reboot
sequence:
- service: shell_command.raspi_reboot
# This part closes the foldable Menu after the tap_action was clicked in the HASS UI
- service: input_boolean.turn_off
entity_id: input_boolean.raspberrypi_menu
4. Nest all Elements inside a custom:vertical-stack-in-card. Please forgive me because I’m too lazy and will post the whole card including all nested cards:
- id: 12345 # Automatically created id
type: custom:vertical-stack-in-card
title: System
cards:
- type: picture-elements
image: /local/entitypictures/raspberrypi.png
elements:
- type: custom:gauge-card
entity: sensor.processor_use
title: CPU
scale: 26px
severity:
green: 0
yellow: 60
red: 85
style:
top: 24%
left: 80%
font-size: 100%
entity: sensor.memory_use_percent
title: CPU
scale: 26px
severity:
green: 0
yellow: 60
red: 85
style:
top: 68%
left: 80%
font-size: 100%
- type: glance
columns: 3
entities:
- entity: sensor.uptime
- entity: sensor.last_boot_format
- entity: input_boolean.raspberrypi_menu
tap_action: toggle
- type: conditional
conditions:
state: "on"
card:
type: glance
columns: 3
entities:
- entity: script.hass_restart
icon: mdi:home-assistant
tap_action: toggle
- entity: script.raspi_reboot
icon: mdi:restart
tap_action: toggle
- entity: script.raspi_shutdown
icon: mdi:power
tap_action: toggle
- entity: script.dasher_restart
icon: mdi:radiobox-marked
tap_action: toggle
- entity: script.mosquitto_restart
icon: mdi:cube-send
tap_action: toggle
- entity: script.gateway_restart
icon: mdi:bluetooth-transfer
tap_action: toggle
Maybe this is helpful to someone. Have fun!
