HI,
Not sure if I named it correctly, but I would like to create an input select to select mp3 files, which I organized in this folder configuration:
would it be possible to have a folder selector first select the correct folder, and following that, have the next input_select show me the options (mp3 files) in that folder? Of course I can make these input_select for each folder. Its the presentation of the appropriate options I am not sure about
I then like to play these files, so I should be able to use the final step in a script like this:
sound_bite:
alias: Sound bite
sequence:
- service: media_player.play_media
data_template:
entity_id: >
{{states('sensor.sound_bite_player')}}
media_content_id: >
{{states('sensor.sound_bite')}}
media_content_type: 'music'
template sensor for the mp3 file:
sound_bite:
friendly_name: Sound bite
value_template: >
{% set state = states('input_select.sound_bite') %}
{% set url = states('input_text.base_url') %}
{% set path = '/local/sounds/sound_bites/'%}
{% set sound_bite = state|lower|replace(' ','_') %}
{% set ext = '.mp3' %}
{{[url,path,sound_bite,ext]|join}}
Id probably need some kind of first input_select.sound_folder and use that for the following steps.
value_template:
{% set option = input_select.sound_folder %}
{% if option == 'Family' %}{{ states('input_select.sounds_family') }}
{% elif option == 'Music' %}{{ states('input_select.sounds_music') }}
{% elif option == 'Nature' %}{{ states('input_select.sounds_nature') }}
# etcetcetc
{% endif %}
or use that for an automation with input_select.select_option?
Please have a look with me, thanks!
