Folder Watcher automation trigger with local_file camera action not working
I have a case where I have a few automations triggered by a file created by the folder_watcher component. The conditions to the automations are to check for a string in the trigger.event and then update the file_path of different local_file cameras so that they show their respective image uploads. The issue I’m having is that all the automations keep updating the same camera file_path and not the individual ones. The automations updating the respective input_text states works as it should, but then the two automations that take the input_texts and updates the camera file_paths always updates to camera.kguard_ch03_gate and never to camera.kguard_last_motion. My automations are below: (any help is appreciated)
# This automation checks for ch02 in the data_path of the folder_watcher create event and updates the respective input_text
- id: '1520095552343'
  alias: Kguard FTP Input Text Update Latest Motion
  - event_data:
      event_type: created
    event_type: folder_watcher
    platform: event
  condition: []
  - condition: template
    value_template: "{{ 'ch02' in trigger.event.data.path }}"
  - service: input_text.set_value
    entity_id: input_text.text_latest_motion
    data_template:
      value: " {{ trigger.event.data.path }} "
# This automation takes the updated input_text state and updated the camera file_path to the same text
- id: '1520333512343'
  alias: Kguard FTP Camera File Path Update Latest Motion
  - platform: state
  - service: camera.local_file_update_file_path
    entity_id: camera.kguard_last_motion
    data_template:
      file_path: " {{ states.input_text.text_latest_motion.state }} "
# This automation checks for ch03 in the data_path of the folder_watcher create event and updates the respective input_text
- id: '1520022252378'
  alias: Kguard FTP Input Text Update CH03 Motion
  - event_data:
      event_type: created
    platform: event
  condition: []
    value_template: "{{ 'ch03' in trigger.event.data.path }}"
    entity_id: input_text.text_ch03_motion
    data_template:
- id: '1533333519243'
  alias: Kguard FTP Camera File Path Update CH03 Motion
  - platform: state
    entity_id: camera.kguard_ch03_gate
    data_template:
      file_path: " {{ states.input_text.text_ch03_motion.state }} "
I’ve also tried the following templates, but it gives the same result:
# This works but always updates to ch03_gate
  alias: Kguard FTP File Path Update Latest Motion
  - event_data:
      event_type: created
    platform: event
  condition: []
    data_template:
      entity_id: >
        {% if 'ch02' in trigger.event.data.path %}
        {% elif 'ch03' in trigger.event.data.path %}
        {% endif %}
      file_path: ' {{ trigger.event.data.path }} '
@albert1 I’m not sure what your exact issue is, or if it is even still relevent to you, but I’ve been working on something very similar for the better part of two weeks and finally got it figured out, in part by referencing your code. You may want to check out my post here, and the context around it, to see if it helps you.
