Folders outside Homeassistant folder in Windows explorer
I’m use my computer running Windows 10 to edit files (notepad ++) on my RP3 running Hassbian 0.61.1.
I have installed samba om my computer, but the only folder I can see in windows explorer chooseing Network/Hassbian is the Homeassistant folder.
I’m not so good at programming so I have to search youtube and forum to get things done.
Some videos / posts on forums referes to folders outside of Home Assistant folder.
What can I do for these folders to appear in windows explorer?
You can use putty to access directories via the command line or if you need a graphical application try Winscp
You need to configure your Samba share on your raspberry pi.
Google for ‘smb.conf’ for explanations on what to put in it to achieve what you want.
That said, if you’re configuring homeassistant you shouldn’t need Samba access to any other files.
