Using Thomas’ Fold Entity Row.
Have an All Automations folding Entity Row and now in 0.90.0b0 with a new frontend, it’s showing a toggle for all automations like this:
This is new I believe… It used to show like this:
As per Thomas’ github.
Tried setting show_header_toggle: false but it ignores it.
@thomasloven is there any way to prevent the toggle showing? On a related note, my All Scenes fold entity row shows unknown as well. Any way for it to just show a dropdown button for both of these?
Correct. This behavior is new to the beta.
The toggle may disappear if you use type: custom:hui-text-entity-row for the head.
Instead of the group I want it to show? Or in addition…??
head:
entity: group.all_automations
I haven’t tested it, though.
Edit: I just checked the code again. That will probably give you an empty list…
ah ok… Is that one of yours? Looking on your github don’t see it…
No. It’s built-in. You don’t need to do anything but change the config.
but then I don’t get the down button to open it up
Edit… not an empty list, no list…
It works on the latest dev branch.
- type: custom:fold-entity-row
head: group.all_lights
head:
entity: group.all_lights
OK yeah that fixed it!
Anyway to stop scenes showing unknown as per the above screenshot?
Thanks for the quick response/fix too.
Mike_i386
(Michael Roll)
March 21, 2019, 5:31pm
11
I’m not sure if this is the right place but since updating to 0.90 today I’m not able to get any kind of tap action on any entity when using the fold entity row card.
Did something change?
Instead of the hand cursor when hovering over it I’m getting the “text mark” cursor.
Mike_i386
(Michael Roll)
March 21, 2019, 6:31pm
12
Nevermind.
I updated all other cards like card-fodder and card-tools and now it works.
Looks like the card “type: custom:fold-entity-row” is rendering strangely. Any ideas why the fold-entity-row card don’t have the normal layoutt?
Closed:
Open:
type: 'custom:fold-entity-row'
head:
type: section
label: Water Sensor Automation
items:
- automation.water_sensor_leakage_loft
- automation.water_sensor_burglar_loft
Using a enteties card gives this:
(System: Home Assistant 0.91.4 /
Hass.io supervisor 162 / HassOS 2.11)
tom_l
May 13, 2019, 1:16pm
14
The fold-entity-row dose not seem to support automation entities:
entities:
- group_config:
toggle: true
type: 'custom:slider-entity-row'
head:
label: Expand
type: section
items:
- entity: automation.hass_startup
- entity: automation.hass_shutdown
- entity: automation.set_light_theme_at_sunrise
- entity: automation.set_dark_theme_at_sunset
- entity: automation.daily_backup_at_1_am
- entity: automation.daily_snapshot_clean_up
- entity: automation.speedtest_peak_time_check
title: Automations - Sysyem
type: entities
It does. I’m using it for that. It might be the space is wrong (before automation). I’ll check when I’m back on my pc.
open: false
head:
type: section
label: Lights & Switches
items:
- automation.coffee_maker_on
- automation.coffee_maker_off
- automation.toothbrush_on
- automation.toothbrush_off
- automation.turn_lounge_light_on_elevation_25deg_after_4pm
Yeah you have the wrong format.
tom_l
May 13, 2019, 11:07pm
16
Thanks daivid.
Looks like I forgot to delete entity: for each item when copy / pasting from the old config. And I forgot to delete the group config that is not applicable to automations.
champ26
(Champ)
August 11, 2019, 5:40pm
17
is there a way i can style the section label?
bobtosh
October 23, 2019, 8:37am
19
Hi, great custom:fold-entity-row. However how to set last-changed to only the entity on head, and not on the entities collapsed? Thx!
Hi all! Is there a way to define the number of rows minimum open?
I think about something like the “custom:battery-state-card” “collapse: 5”
