Ran into some issues. Can’t be sure if it’s because the video I followed was over two years old or not. It appears the script is up-to-date and functioning. After installing python on my windows 10 box I’ve dedicated for this activity. I see the same firewall pop-up as in the video. I accept. And I originally got a bunch of errors about missing modules. But then ran the command again with CMD in admin mode and things progressed further. Eventually i see [homeassistant.core] Starting Home Assistant - Timer starting… however NO UI ever pops up, rather an auto-discovery process begins. It fumbles a bit with my ps3’s DLNA server… then gets hung up on my Samsung Set Top Box. (second cable box)
2019-02-10 10:25:28 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 3.07s
2019-02-10 10:25:28 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-02-10 10:25:28 INFO (MainThread) [homeassistant.core] Timer:starting
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dmr {'host': '192.168.1.166', 'port': 7676, 'ssdp_description': 'http://192.168.1.166:7676/smp_12_', 'name': '[STB]GX-SM530CF', 'model_name': 'SM530CF', 'model_number': 'AllShare1.0', , 'manufacturer': 'Samsung Electronics', 'udn': 'uuid:127a3980-0036-1000-a373-1077b1abe5dd', 'upnp_device_type': 'urn:schemas-upnp-org:device:MediaRenderer:1'}
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.loader] Loaded cast from homeassistant.components.cast
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.loader] Loaded upnp from homeassistant.components.upnp
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.components.discovery] Found new service: samsung_tv {'host': '192.168.1.166', 'port': 7676, 'ssdp_description': 'http://192.168.1.166:7676/smp_3_', 'name': '[STB]GX-SM530CF', 'model_name': 'GX-SM530CF', 'model_number': '1.0', 'serial': '20090804RCR', 'manufacturer': 'Samsung Electronics', 'udn': 'uuid:127a3981-0036-1000-b709-1077b1abe5dd', 'upnp_device_type': 'urn:samsung.com:device:RemoteControlReceiver:1'}
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: spotify_connect {'host': '192.168.1.108', 'port': 52155, 'hostname': '25d2051019ca6596-0.local.', 'properties': {'CPath': '/zc/0', 'VERSION': '1.0', 'Stack': 'SP'}}
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.setup] Setting up media_player
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.0 seconds.
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.loader] Loaded media_player.samsungtv from homeassistant.components.media_player.samsungtv
2019-02-10 10:25:41 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.samsungtv
2019-02-10 10:25:41 INFO (SyncWorker_3) [homeassistant.components.media_player.samsungtv] Samsung TV 192.168.1.166:55000 added as '[STB]GX-SM530CF (GX-SM530CF)'
2019-02-10 10:25:52 INFO (SyncWorker_5) [root] Sending handshake.
2019-02-10 10:25:52 WARNING (SyncWorker_5) [root] Authorization cancelled.
2019-02-10 10:26:03 INFO (SyncWorker_13) [root] Sending handshake.
2019-02-10 10:26:03 WARNING (SyncWorker_13) [root] Authorization cancelled.
2019-02-10 10:26:14 INFO (SyncWorker_4) [root] Sending handshake.
2019-02-10 10:26:14 WARNING (SyncWorker_4) [root] Authorization cancelled.
2019-02-10 10:26:25 INFO (SyncWorker_14) [root] Sending handshake.
2019-02-10 10:26:25 WARNING (SyncWorker_14) [root] Authorization cancelled.
2019-02-10 10:26:35 INFO (SyncWorker_15) [root] Sending handshake.
2019-02-10 10:26:35 WARNING (SyncWorker_15) [root] Authorization cancelled.
2019-02-10 10:26:46 INFO (SyncWorker_2) [root] Sending handshake.
2019-02-10 10:26:46 WARNING (SyncWorker_2) [root] Authorization cancelled.
2019-02-10 10:26:57 INFO (SyncWorker_16) [root] Sending handshake.
2019-02-10 10:26:57 WARNING (SyncWorker_16) [root] Authorization cancelled.
then it gets stuck in this loop of trying the handshake and never stops. I let it run for over a half hour. I even attempted blocking the device by Mac address in my router… rebooted the router … no DHCP lease to that IP anymore… and re-ran the script… and i’ll be damned if it didn’t find it again… and start this loop again… even without it connected to my network WTF!
Did it save this info into configuration the first time it ran? Can I remove it? What is happening here exactly? why is it trying to get root on my samsung cable box? i’m so confused. two commands in the video set up… but zero troubleshooting …
