I will offer up a firm handshake to anyone that can explain to me what in the *heck is going on with my set-up.
End goal: run mosquitto broker and start zigbee2mqtt
What’s happening: mosquito broker won’t start one day, then it’s back online other days. Some days cloudflared add-on goes down then back up. Just recently studio code server went down and then up and now back down. I just do not understand what’s happening and why it continues to occur. I follow the online step by step guides and either they aren’t informative enough or don’t relate to my problem. Can someone give me a sense of direction of next steps at this point?
What hardware are you running HA on and what kind of install do you have?
Raspberry Pu and HA 2022.11
Is there anything in the logs for the add-ons that gives any clues?
My view
So many greyed out stuff that doesn’t work.
Logs:
2022-11-07 14:02:38: Saving in-memory database to /data//mosquitto.db.
2022-11-07 14:32:39: Saving in-memory database to /data//mosquitto.db.
2022-11-07 15:02:40: Saving in-memory database to /data//mosquitto.db.
2022-11-07 15:32:41: Saving in-memory database to /data//mosquitto.db.
2022-11-07 16:02:42: Saving in-memory database to /data//mosquitto.db.
2022-11-07 16:32:43: Saving in-memory database to /data//mosquitto.db.
2022-11-07 17:02:44: Saving in-memory database to /data//mosquitto.db.
2022-11-07 17:32:45: Saving in-memory database to /data//mosquitto.db.
2022-11-07 17:59:34: New connection from 194.26.29.11:62442 on port 1883.
2022-11-07 17:59:34: Client <unknown> disconnected due to protocol error.
2022-11-07 18:02:46: Saving in-memory database to /data//mosquitto.db.
2022-11-07 18:32:47: Saving in-memory database to /data//mosquitto.db.
2022-11-07 19:02:48: Saving in-memory database to /data//mosquitto.db.
2022-11-07 19:32:49: Saving in-memory database to /data//mosquitto.db.
2022-11-07 20:02:50: Saving in-memory database to /data//mosquitto.db.
2022-11-07 20:32:51: Saving in-memory database to /data//mosquitto.db.
2022-11-07 21:02:52: Saving in-memory database to /data//mosquitto.db.
2022-11-07 21:32:53: Saving in-memory database to /data//mosquitto.db.
2022-11-07 22:02:54: Saving in-memory database to /data//mosquitto.db.
2022-11-07 22:32:55: Saving in-memory database to /data//mosquitto.db.
2022-11-07 23:02:56: Saving in-memory database to /data//mosquitto.db.
2022-11-07 23:32:57: Saving in-memory database to /data//mosquitto.db.
2022-11-08 00:02:58: Saving in-memory database to /data//mosquitto.db.
2022-11-08 00:32:59: Saving in-memory database to /data//mosquitto.db.
2022-11-08 01:03:00: Saving in-memory database to /data//mosquitto.db.
2022-11-08 01:33:01: Saving in-memory database to /data//mosquitto.db.
2022-11-08 02:03:02: Saving in-memory database to /data//mosquitto.db.
2022-11-08 02:33:03: Saving in-memory database to /data//mosquitto.db.
2022-11-08 03:03:04: Saving in-memory database to /data//mosquitto.db.
2022-11-08 03:33:05: Saving in-memory database to /data//mosquitto.db.
2022-11-08 04:03:06: Saving in-memory database to /data//mosquitto.db.
2022-11-08 04:33:07: Saving in-memory database to /data//mosquitto.db.
2022-11-08 05:03:08: Saving in-memory database to /data//mosquitto.db.
2022-11-08 05:33:09: Saving in-memory database to /data//mosquitto.db.
2022-11-08 06:03:10: Saving in-memory database to /data//mosquitto.db.
2022-11-08 06:30:40: New connection from 167.94.138.63:46236 on port 1883.
error: received null username or password for unpwd check
2022-11-08 06:30:40: Client <unknown> disconnected, not authorised.
2022-11-08 06:33:11: Saving in-memory database to /data//mosquitto.db.
2022-11-08 07:03:12: Saving in-memory database to /data//mosquitto.db.
2022-11-08 07:33:13: Saving in-memory database to /data//mosquitto.db.
2022-11-08 08:03:14: Saving in-memory database to /data//mosquitto.db.
2022-11-08 08:33:15: Saving in-memory database to /data//mosquitto.db.
2022-11-08 09:03:16: Saving in-memory database to /data//mosquitto.db.
2022-11-08 09:33:17: Saving in-memory database to /data//mosquitto.db.
2022-11-08 10:03:18: Saving in-memory database to /data//mosquitto.db.
2022-11-08 10:33:19: Saving in-memory database to /data//mosquitto.db.
2022-11-08 11:03:20: Saving in-memory database to /data//mosquitto.db.
2022-11-08 11:33:21: Saving in-memory database to /data//mosquitto.db.
2022-11-08 12:03:22: Saving in-memory database to /data//mosquitto.db.
2022-11-08 12:33:23: Saving in-memory database to /data//mosquitto.db.
2022-11-08 13:03:24: Saving in-memory database to /data//mosquitto.db.
2022-11-08 13:33:25: Saving in-memory database to /data//mosquitto.db.
2022-11-08 14:03:26: Saving in-memory database to /data//mosquitto.db.
2022-11-08 14:33:27: Saving in-memory database to /data//mosquitto.db.
2022-11-08 15:03:28: Saving in-memory database to /data//mosquitto.db.
2022-11-08 15:33:29: Saving in-memory database to /data//mosquitto.db.
2022-11-08 16:03:30: Saving in-memory database to /data//mosquitto.db.
2022-11-08 16:33:31: Saving in-memory database to /data//mosquitto.db.
2022-11-08 17:03:32: Saving in-memory database to /data//mosquitto.db.
2022-11-08 17:33:33: Saving in-memory database to /data//mosquitto.db.
2022-11-08 18:03:34: Saving in-memory database to /data//mosquitto.db.
2022-11-08 18:33:35: Saving in-memory database to /data//mosquitto.db.
2022-11-08 19:03:36: Saving in-memory database to /data//mosquitto.db.
2022-11-08 19:33:37: Saving in-memory database to /data//mosquitto.db.
2022-11-08 20:03:38: Saving in-memory database to /data//mosquitto.db.
2022-11-08 20:33:39: Saving in-memory database to /data//mosquitto.db.
2022-11-08 21:03:40: Saving in-memory database to /data//mosquitto.db.
2022-11-08 21:33:41: Saving in-memory database to /data//mosquitto.db.
2022-11-08 22:03:42: Saving in-memory database to /data//mosquitto.db.
2022-11-08 22:30:34: Client 2w2OJmrBji1mvKookSQnDf closed its connection.
2022-11-08 22:31:06: New connection from 172.30.32.1:51249 on port 1883.
2022-11-08 22:31:06: New client connected from 172.30.32.1:51249 as 1aHcwrUaT1XMaZqFjWNkxU (p2, c1, k60, u'homeassistant').
2022-11-08 22:33:43: Saving in-memory database to /data//mosquitto.db.
2022-11-08 23:03:44: Saving in-memory database to /data//mosquitto.db.
2022-11-08 23:33:45: Saving in-memory database to /data//mosquitto.db.
2022-11-09 00:03:46: Saving in-memory database to /data//mosquitto.db.
2022-11-09 00:33:47: Saving in-memory database to /data//mosquitto.db.
2022-11-09 01:03:48: Saving in-memory database to /data//mosquitto.db.
2022-11-09 01:33:49: Saving in-memory database to /data//mosquitto.db.
2022-11-09 02:03:50: Saving in-memory database to /data//mosquitto.db.
2022-11-09 02:33:51: Saving in-memory database to /data//mosquitto.db.
2022-11-09 03:03:52: Saving in-memory database to /data//mosquitto.db.
2022-11-09 03:33:53: Saving in-memory database to /data//mosquitto.db.
2022-11-09 04:03:54: Saving in-memory database to /data//mosquitto.db.
2022-11-09 04:33:55: Saving in-memory database to /data//mosquitto.db.
2022-11-09 05:03:56: Saving in-memory database to /data//mosquitto.db.
2022-11-09 05:33:57: Saving in-memory database to /data//mosquitto.db.
2022-11-09 06:03:58: Saving in-memory database to /data//mosquitto.db.
2022-11-09 06:33:59: Saving in-memory database to /data//mosquitto.db.
2022-11-09 07:04:00: Saving in-memory database to /data//mosquitto.db.
2022-11-09 07:34:01: Saving in-memory database to /data//mosquitto.db.
2022-11-09 08:04:02: Saving in-memory database to /data//mosquitto.db.
2022-11-09 08:09:12: New connection from 162.142.125.221:41210 on port 1883.
2022-11-09 08:09:12: Client <unknown> disconnected, not authorised.
2022-11-09 08:34:03: Saving in-memory database to /data//mosquitto.db.
2022-11-09 09:04:04: Saving in-memory database to /data//mosquitto.db.
2022-11-09 09:22:27: New connection from 74.82.47.5:56948 on port 1883.
