It would be handy to be able to specify minimum and maximum brightness as a percentage in the light/entity settings, so dimmer sliders will only function to those limits.
Eg: if you set minimum to 15%, when you slide the dimmer all the way to 0%, it will actually only dim the light to 15%, preventing any low power flicker.
