I’m using for_each to iterate over a list of media_players which I feed into the script as a parameter. I needed to work around an issue in not being able to use the same mechanism as I would use for other services where you can pass in either a single entity or a comma separated list of entity_ids e.g.
entity_id: media_player.my_player_1 or entity_id: media_player.my_player_1, media_player.my_player_2
The second case doesn’t work with for_each as the parameter is a string, not a list.
If I bracket the parameter to be a list
Here’s how the code looks like, the workaround is to create a group on the fly - which accepts either a single or multiple entity_ids and then use the groups entity_id state_attribute to iterate over.
media_player_speak:
sequence:
- service: group.set
object_id: media_player_temp_group
entities: "{{ entity_id }}" # entity_id is the parameter passed intothe script
- repeat:
for_each: "{{ state_attr('group.media_player_temp_group', 'entity_id')|list }}"
# do something with repeat.item
- service: group.remove
object_id: media_player_tmp_group
# the calling sequence looks like this:
- service: script.media_player_speak
message: "hello"
I wonder if this can be done more elegantly - w/o the need of the temporary group.
thank you very much. Your solution, the second way with the split (the first one I had known but wanted it to function like w/ other services) is great and make we wonder why I didn’t get to that simple solution myself (now that I see it ).
Adding more info: I am able to reproduce the problem with a simple script with a hard coded list variable (not taking in a parameter) and I see the same problem. I think it’s an issue with the way area_id is parsed. I’ll raise this issue somewhere else
