As mentioned in the title, the for attribute on the template does not have access to variables defined in the script/automation. This was specially confusing for me since the documentation does not mention this being a special case, nor any errors or warnings are raised if for: renders to some invalid data. Is this expected behaviour?
Here’s a minimal test to validate what I’m experiencing. The following code will get a for: { seconds: 2 } meaning that test_sensor is accessible in that scope.
alias: "Test: wait template for"
description: ""
trigger: []
condition: []
- variables:
# change this to any sensor you can use to test
test_sensor: binary_sensor.macroled_mini_relay_3_switch_2
- wait_for_trigger:
value_template: "{{ is_state(test_sensor, \"on\") }}"
for:
seconds: "{{ 1 if test_sensor is defined else 2 }}"
mode: single
description: ""
variables:
trigger: []
condition: []
- wait_for_trigger:
for:
mode: single
Does this also work if I modify the variable within the automation? I’m doing this inside a while loop and the timer varies each iteration (exponential backoff).
Didn’t work, the variable is not defined. Tried it with this:
description: ""
trigger: []
condition: []
- variables:
must_be_true: true
- wait_for_trigger:
for:
# 1: defined correctly
# 2: defined but previous block didn't change the value
# 3: not defined at all
seconds: "{{ (1 if must_be_true else 2) if must_be_true is defined else 3 }}"
variables:
must_be_true: false
mode: single
Even if the variable is available everywhere, I don’t think that guaratees that it’ll have the an up to date value, it could just hold the value defined in the variables: section outside the action list.
All pieces of code reference the same identifier but not the same value. The for template might be able to reference the variable at the variables section but not the updated value set in the actions section.
Either way using the variables section didn’t work so this distinction is kinda pointless.
Nope. By defining the varable at the top level the variable is global to the automation and actions are executed in sequence. So after the test action the variable has been updated and it would actually print:
