Hi folks, is there a elegant way for adding a on time on a wait_template, like “for” in triggers?
Background: The automation triggers, does something and then should wait until a numeric value (in this case current) is under a certain value for e.g. 5 minutes - I know I could do it with a second automation which is triggered by the first one, but working in one automation would be nicer - thanks!
something like this:
wait_for_trigger:
- platform: numeric_state
entity_id: sensor.fuse_box_meter_channel_1_power
for:
hours: 0
minutes: 5
seconds: 0
below: '100'
Ah, didn’t know I can use all trigger platforms - I’ll give a try - thank you!
