Hello, i need to iterate over a json reply and set to true only if all values are true, below the code that won’t work…
command_state: >-
sleep 10; StatusCams=$(curl -s -X GET http://192.168.0.23:6475/api/config); for status in $(echo $StatusCams | jq '.cameras.[].enabled'); do if [ $status == "true" ]; then echo "true"; else echo "false" && break; fi; done
value_template: >-
{{ value == "true" }}
The command call the API here “http://192.168.0.23:6475/api/config” and put the Json reponse in variable StatusCams the iterate with for loop and break only if find a false.
If i run this command in shell works well:
The last value is false so false should be the value evaluated and in HA i can see that the sensor is OFF, but when all cameras are true i still see that the sensor is OFF:
Seems something related to break of for loop?
I hope someone could help me ![]()
