sinty
(Andrei Shcherbakov)
1
Hi!
I want to make some automation that use actual HA configuration to build inline keyboard inside telegram bot.
I try to use code like this:
- alias: ‘Telegram light response’
hide_entity: true
platform: event
event_type: telegram_command
event_data:
command: ‘/light’
- service: telegram_bot.send_message
data_template:
title: ‘Hello!’
message: ‘Light!’
inline_keyboard: >-
{% for state in states.light -%}
- /light_on_{{state.entity_id}}
{% endfor %}
But it doesn’t work.
Error in log file:
2018-04-08 11:59:33 ERROR (SyncWorker_1) [homeassistant.components.telegram_bot] Error sending message: Button_data_invalid. Args: (11763502, ‘Hello!\nLight!’), kwargs: {‘parse_mode’: ‘Markdown’, ‘disable_notification’: False, ‘disable_web_page_preview’: None, ‘reply_to_message_id’: None, ‘reply_markup’: <telegram.inline.inlinekeyboardmarkup.InlineKeyboardMarkup object at 0x7f0afa0c0278>, ‘timeout’: None}
What’s wrong?
hokus15
(Hokus15)
3
Did you find a solution, I’ve a similar problem.
sinty
4
Yes. But I use appdaemon for telegram bot now. It allows make more complex things.
My code is working:
{%- for r in states.switch -%}
{% if r.state=='on'%}
{{'[["'}}{{r|regex_findall_index('\.(\w+)')}}{{-'","/actionlink"]]'-}}
{%- if loop.last == false %},
{%- endif -%}
{%- endif -%}
{%- endfor -%}
TheFes
(The Fes)
6
You can’t template YAML like that. But you can use a list output from a template directly
So this should work:
- alias: 'Telegram light response'
hide_entity: true
platform: event
event_data:
command: '/light'
data_template:
title: 'Hello!'
message: 'Light!'
inline_keyboard: >
states.light
| map(attribute='entity_id')
| map('regex_replace', '^' , ' /light_on_')
| list
TheFes
(The Fes)
7
Does this give the same result as your template?
~ states.switch
| map(attribute='object_id')
| list
| join('","/actionlink"]], [["')
~ '","/actionlink"]]]'
Not sure why you need all these nested lists, but I don’t use the telegram integration, so it might be required ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=12)
petro
(Petro)
8
I assumed it was some sort of odd markdown language to make buttons.
