I have a large batch of Insteon devices that are looking for a new home.
$100 if you can pick them up in south Orange County, CA.
As far as I know they are all working, with the possible exception of the PLM (which may be failed, or may have just overheated temporarily the last time I used it):
Insteon 2-wire dimmer switch 2474DWH rev 6.7 2218
Insteon 8-button Mini-remote #2342-2 V2.0 1837
Insteon ApplianceLinc plug-in switch #2456S3 0552 rev 1.1
Insteon ApplianceLinc plug-in switch #2456S3 V4.5 1149
Insteon ApplianceLinc plug-in switch #2456S3 V4.6 1213
Insteon Dimmer Switch 2477D rev 7.8
Insteon Dimmer Switch 2477D Rev 8.2 1417
Insteon Dimmer Switch 2477D Rev 8.2 3118 (New in box)
Insteon I/OLinc Model 2450 V2.4 1548 + Somfy Dry Contact Interface
ICON In-Wall On/Off Switch #2876SB V5.4 1030
ICON On/Off Adaptor #2856S3B V4.5 1025
Insteon In-LineLinc Relay #2475S2 V5.7 1145
Insteon In-LineLinc Relay #2475SDB V7.2 2419
Insteon In-LineLinc Dimmer (Dual-Band) #2475DA1 (New in box)
Insteon Leak Sensor 2852-222 #0114 Rev2.1
Insteon Leak Sensor 2852-222 #1217 Rev2.6
Insteon Leak Sensor 2852-222 #2213 Rev2.0
Insteon Mini Remote 2342-2 V1.8 1647
Insteon Mini Remote 2342-2 V2.0S 1631
Insteon PLM #2413U rev 2.3 2317 (Replaced capacitors 12/26/21; might have failed again, not sure if working)
Insteon SignaLinc RF #2442 0602 rev 2.0 V1.0 2335
Insteon SignaLinc RF #2442 0602 rev 2.0 V1.0 2171
Insteon Smoke Bridge Model 2982-222 R3.3 3013
Insteon SwitchLinc On/Off Switch #2476S V6.0 1214 (New in box)
Insteon SwitchLinc On/Off Switch #2477S V7.0 3515 (New in box)
Insteon FilterLinc On/Off Switch #1626-10 Electrical Noise Filter (New in box)
Insteon Access Point #2443 V2.4 1022
Insteon ICON On/Off Adaptor #2856S3B V4.5 1025
