I have seen countless of posts regarding finding the token for Xiaomi Vacuum cleaners with 5-6 different “solutions” with one of the suggested methods in the documentation of using MiToolKit to extract the token.
For those who tried this and just got the IP out, even when downgrading you could try the following
- Install the 5.0.19 version of the app
- Make sure MiToolKit is closed
3. Delete the folder inside the “MiToolkit.1.6\MiToolkit 1.6\apps” - this is where I didnt figure it out - if you try to run this application it for me did NOT overwrite the old version I first tried with - Rerun the extraction and the program should make a new folder including the token.
Simple solution, no need to readding the vacum, changing servers etc (I didnt even setup the vacum on the phone I used), and used EU server. The only issue was that the first folder created did not get overwritten so even when downgrading the app on the phone it just present the old files, so remember to delete it or it wont work.
