I have a problem with Netatmo valves and am wondering if I can solve it with HA. I’ve tried resolving it with Netatmo support, but those attempts failed.
All my radiators are equipped with Netatmo valves, connected with the relay to my boiler which runs on heater oil. So far so good. My warm water reservoir is also connected with the boiler. This is where the problem starts. When the warm water reservoir turns on the boiler (i.e. if temp is below a certain threshold), the hot water also runs through radiators which are still open (even if already above set temperature). This is because the radiator valves do not close when all rooms/valves have reached the desired temp, to save battery. In my setup this is a huge problem, causing random rooms to heat up a lot higher then requested, on random times.
Now my actual question : Can I somehow force/control valves to close after desired/set temp was reached?
