jayha
(jay)
July 21, 2017, 3:06am
1
i tried to scan from my second device for bluetooth tracker, but the device does not show up in known devices.
i did also go to services and tried device_tracker / see. while running scan on the phone.
how can i get a new device added here?
Thanks,
keithh666
(Keith Hull)
July 21, 2017, 9:57pm
2
I think you need to initially set the phone to enable BT visibility otherwise HA won’t see it. Setting scan on the phone won’t enable HA to see it as the phone scans but doesn’t enable visibility.
jayha
(jay)
July 24, 2017, 12:34am
3
i have it enabled but no luck…
keithh666
(Keith Hull)
July 24, 2017, 2:38pm
4
You haven’t given any clue what HW you are using for either HA or your phone? Bit hard to diagnose anything with no info
jayha
(jay)
July 24, 2017, 2:49pm
5
sorry, here it is. running current HA on pi.
the phone is a galaxy s8… that i am trying to get added… BTW i have another S8 thats added just fine.
I also took device_tracker out of the the config size; restarted and add it back in.
keithh666
(Keith Hull)
July 24, 2017, 3:00pm
6
If you have BT enabled and running on the PI you can open a terminal window and type bluetoothctl then type scan on. If your phone BT is enabled and is visible then you should see it after a few seconds or so. That will prove the phone and the PI are working, then we can see what’s up with S8 that can’t be seen in HA.
jayha
(jay)
July 24, 2017, 3:12pm
7
thanks, i will try this when i am home.
BTW:
[bluetooth]# scan on
Discovery started
[CHG] Controller B8:27:EB:12:4D:12 Discovering: yes
keithh666
(Keith Hull)
July 24, 2017, 3:50pm
8
Discovery started
[CHG] Controller 00:1A:7D:DA:71:13 Discovering: yes
[CHG] Device F2:F1:09:E6:DE:78 RSSI: -57
[NEW] Device xx:xx:xx:xx:xx:xx Keith Hull (Galaxy S5) ----- my phone
[NEW] Device C4:7C:8D:6D:2D:6D ropot
keithh666
(Keith Hull)
July 24, 2017, 4:10pm
10
OK, hopefully it will tell us whether the phone is working OK, then we can try to figure out why HA isn’t seeing it.
jayha
(jay)
July 25, 2017, 1:44pm
11
the phone appeared in HA… didnt do anything different this time…
Thanks for your help Keith.
keithh666
(Keith Hull)
July 25, 2017, 2:46pm
12
Yep, probably you didn’t wait long enough
