Force Temperature to Fahrenheit?
The ecowitt integration is now Celsius and won’t go back to Fahrenheit. Dude wtf
Don’t know what you expect, but a solution could be to create a custom sensor that calculates Fahrenheit.
The calculation isn’t hard: (TempC x 1.8) + 32 = TempF
From F to C, for those interested: (TempF - 32) x (5/9) = TempC
Oh that’s actually easier than I thought it would be with the maths.
How would I put that in template though to make a sensor? I tried and nothing showed up. It’s just making “sensor.mainroomtemperature1c” into something in Fahrenheit called “sensor.mainroomtemperature1”
Here is how to make a template sensor.
Your template should look something like:
  (states('sensor.temp_c')|float(0) * 1.8 + 32) | round
i did this?
      - name: mainroomtemperature1
        unit_of_measurement: '°F'
        value_template: >-
          {% set t = states('sensor.mainroomtemperature1c') | float %}
          {{((t)*9/5)+32}}
The below code should be added to your configuration.yaml file, assuming your sensor is actually named ‘sensor.mainroomtemperature1’.
If this is the first custom sensor, then it should be just copy/past. if it’s not your first, skip the sensor: and put it in line with the other custom sensors.
    sensors:
      mainroomtemperature1f:
        friendly_name: "Temp F"
        icon_template: mdi:temperature-fahrenheit
        value_template: "{{ (states('sensor.mainroomtemperature1c')|float(0) * 1.8 + 32) | round }}"
The new sensor of this example is named sensor.mainroomtemperature1f.
You can try to reload via ‘Developer Tools’ → ‘YAML’ → ‘Template Entities’, but first check the config by clicking ‘Check configuration’ in that same screen.
edit:
P.s. your calculation is likely to be incorrect based on the calculation rules. Multiplying goes before dividing, so it should be (states('sensor.mainroomtemperature1c')|float(0) * (9/5) + 32) | round.
that makes sense now. thanks.
You’re welcome.
If you mark it as solution, it’s easier to find for others that have the same issue/need :+1:
How do I do that?
If I remember correctly the topic starter can just mark it at the bottom of the specific post.
I did a quick search and it seems that your topic must have a category, which yours doesn’t seem to have.
So I’d suggest you add a category first. You can do so by clicking the pencil at your topic title. Then mark a post as a solution.
That’s kinda stupid.
I’d say that this post (post 7) is the solution, and not the post that describes how to mark a post as a solution :wink:
I mean it was a solution for solutions. It was solution-ception. Gotta give it to Leonardo DiCaprio. Anything that convoluted and confusing must be a good movie. I think that’s how that works.
