The new UI is confusing to me. What are these switches for?
They are for switching everything in the card on/off. If you don’t want them (or they are inappropriate for the card entities) you can edit the card and disable it:
In your case, the switch doesn’t make sense. You can hide them by turning the switch off:
Show Header Toggle? --> set it to inactive (when you use the new lovelace frontend editor)
or add this to your code: “show_header_toggle: false”
Have a look at the demo: https://demo.home-assistant.io/
If you have sub-switches, you can turn all of them on or off (nice feature )
