Tonight I decided to flash a few smart LED strips with Tasmota. The tool I use for this (tuya-convert) installed vanilla (non-dockerised) Mosquitto, which took over port 1883 and made the Home Assistant version very upset. I purged Mosquitto so the docker version could start up again.
In my troubleshooting attempts I removed and re-added both the MQTT add on and the MQTT integration. Now I’ve added both back, and I think everything’s working. The add-on shows a green light in supervisor and has my devices in the logs. If I open the integration, I can listen to # and see all five of the devices checking in from time to time. But none of them are showing up in Devices or Entities, or on my homescreen; and where the MQTT integration once said “5 devices” it now just says nothing. If I go into the integration overflow -> System options, “Enable newly added entities” is checked.
Is there something I’m missing here? If the MQTT integration can “hear” all 5 of my devices when I listen to the # topic, how can I make it add them to Devices / the home screen like it used to do?
Thanks in advance! Running the custom Linux install version on Ubuntu, v 0.115.3.
