Forecast.solar forecast with panels on both sides of the roof
What do you set the inverter limit to if it’s total capacity is less than the total panel capacity?
e.g. I have 2.64kW of panels on the north roof and 3.96W on the east, totalling 6.6kW, but with only a 5kW inverter.
Each integration has it’s own inverter limit, but dividing the 5kW limit to 2kW for the north plane, and 3kW for the east, wouldn’t represent the real world.
If I set each integration’s inverter limit to 5kW, the total power wouldn’t be reduced when the total exceeds 5kW since neither can independently produce 5kW.
If I set the inverter limits to 2kW and 3kW, each plane would have power reduced when they reach their independent limit, even if the other plane isn’t producing enough to total 5kW.
