Adding a “Select” type entity to HA through MQTT discovery.
(Got light,Sensor, number working)
The Select entity has a configuration variable “options” (which is required) and is of the type list
Unfortunately, there is no example for Select- type entities.
So, where for the variable name , the code would look like:
doc[“name”] = “myName”;
I am struggeling to find how to add the variable options to the payload of the /config topic
doc[“options”] = "one, two, three " gives one single option named one,two,three
I have tried creating a nested object , but then my options in HA are called [object :Object]
What should the syntax of a list in the Json payload of the entity look like?
{"name":"This Select","obj_id":"some selct","uniq_id":"ofclght4B10Q","options":"one;two;thre","stat_t":"stat/off_light/select","cmd_t":"cmnd/off_light/select","device":{"ids":"devofclight01","name":"Office Light"}}
does not work
