Formatting Issues:
I recently started using Node-Red (LOVE IT!) but have run into a formatting issues that I can’t resolve:
I have a few different device trackers that feed into a format node that does the following:
msg.paylod is set to
Copy to clipboard
"data": {
"dev_id": "USERS_tracker",
"location_name": "{{payload}}"
Format is Mustache template
Output as Parsed YAML
The message then travels a little bit and ends up at a service call node that runs the device_Tracker.see on it.
If I use the developers tools to change the state of a device tracker to USER’S work, I get the following output from my format node USER & # 39 ; (no spaces) S work. how do I get a ’ instead of the & # 39 ; (no spaces) ?
