My end goal is to send a randomly selected text string via MQTT Publish.
So far I have this working but it breaks if the strings have spaces (nothing gets spoken by the wall panel).
payload_template: '{"speak": {{ ["test1”, "test2”] | random }}}'
topic: wallpanel/kitchen/command
to_json (doc) seems like the a possible solution if I could write it to use random like the above example but I can’t even get a basic example to work with MQTT Publish. At least not under Developer Tools > Services. Just gives syntax errors and won’t let me submit. I believe the jinja {% %} syntax is only available for templates?
{% set test = {'speak': 'test'} %}
payload_template: {{ test|to_json }}
At this point maybe making a template using the to_json filter (with random selection integrated somehow) and then pulling that into the MQTT Publish call is what I need?
Open to any suggestions that might help me reach my end goal.
Not sure what you’re getting at. Escaping is not the issue in this case. My test when using payload (not shown) all worked fine just by using proper quoting (combination of single / double quotes like in my example), no \ escapes necessary.
For example with payload_template…
This works (proper quoting so escapes are not required)
payload_template: '{"speak":{{ ["test1", "test2"] | random }}}'
Also note that I switched to payload_template because it allows for the {{ }} syntax and random, etc. to_json is supposed to be a simpler, cleaner way of generating json for such things I believe it’s just that it cannot be used in Developer Tools > Services or Automations, etc or rather the jinja portion {% %} cannot, only in config files, I think?
