I’ve read the documentation, and it’s not exactly clear (or I’m too much of a novice to understand it properly), so I’m hoping someone might be able to explain a little more about MQTT triggers with a JSON payload.
I’m using zigbee2MQTT, and there are three formats for delivery:
- json
- attribute
- attribute_and_json
The ‘json’ option is formatted as a single message with all attributes in an array:
info 2023-12-31 01:37:27MQTT publish: topic 'zigbee2mqtt/Console', payload '{"current":0.12,"energy":141.4,"last_seen":"2023-12-31T07:37:27.940Z","linkquality":76,"power":10.4,"state":"OFF","voltage":124.42}'
The ‘attribute’ option sends each item in the array as a single message:
info 2023-12-31 01:37:27MQTT publish: topic 'zigbee2mqtt/Console/state', payload 'OFF'
info 2023-12-31 01:37:27MQTT publish: topic 'zigbee2mqtt/Console/power', payload '10.4'
info 2023-12-31 01:37:27MQTT publish: topic 'zigbee2mqtt/Console/current', payload '0.12'
info 2023-12-31 01:37:27MQTT publish: topic 'zigbee2mqtt/Console/voltage', payload '124.42'
info 2023-12-31 01:37:27MQTT publish: topic 'zigbee2mqtt/Console/energy', payload '141.4'
info 2023-12-31 01:37:27MQTT publish: topic 'zigbee2mqtt/Console/linkquality', payload '76'
info 2023-12-31 01:37:27MQTT publish: topic 'zigbee2mqtt/Console/last_seen', payload '2023-12-31T07:37:27.940Z'
The attribute_and_json option sends both in sequence, with the json coming first.
If I use the ‘attribute’ or ‘attribute_and_json’ option, I can specify the attribute in the trigger as part of the topic:
- platform: mqtt
topic: zigbee2mqtt/Dining Light Switch/action
payload: config_single
- platform: mqtt
payload: config_double
condition: []
If I use only the ‘attribute’ option, the entities seemingly don’t update their states due to how the MQTT integration parses MQTT messages. I’ve been using the 'attribute_and_json option, which seems to be working fine, but it makes my network very chatty by greatly increasing the number of messages, cluttering up the logs. I also have other non-z2m devices that only format their message as a JSON array, so my question is this:
Is it possible to parse pieces of the JSON array in the payload option of the trigger, and what would that YAML look like?
I’m aware it’s possible to template a condition, but I really don’t want to do that because it makes traces a nightmare since the automation triggers everytime a message is received on that device (or potentially more, if using wildcards).
