Looking for a little help, I’ve been stuck on this problem or a couple of days.
I’m using a Mushroom template card to create a custom display of my Anthem AV receiver’s status. I’m stuck on formatting the number returned for the volume level. Currently the volume on the receiver is configured to report as a percentage. However, the template is displaying it as a decimal number. For example, if the volume is set to 10% the displayed volume is 0.10.
How do I write the following template to display as a whole number with a % sign?
Currently I have:
{{ 'On' if is_state('media_player.anthem_av', 'on') else 'Off' }} - {{state_attr('media_player.anthem_av', 'volume_level') if is_state('media_player.anthem_av', 'on') else ' ' }} - {{state_attr('media_player.anthem_av', 'source') if is_state('media_player.anthem_av', 'on') else 'Off' }}
That’s awesome!
And it worked well in the Developer Tools experimental area.
However, when I defined a new sensor in configuration.yaml with this style of formatting I just get “undefined” as result.
Anyone any idea why this might be?
When you specify that unit of measurement, don’t have the extra percentage sign in the format function and ensure your value is in the range 0…100, not 0…1.
State attributes preserve their type, so no need for a float filter.
If this seems confusing: the previous answer assumed there was no unit of measurement: just a template sensor with a text value (not a numeric one), preformatted. If you want that, remove the unit of measurement. Otherwise, use the solution given here.
