Thanks for the reply.
I am using an unofficial Kidde Smoke Detector integration for HA.
https://github.com/865charlesw/homeassistant-kidde
The integration is based on a Python Wrapper but only pulls data for Smoke and Co2 from the API
My device also has Air Quality Sensors that I would like to use in HA.
To get the data seen in my initial screenshot, I had to add sensors into the integration using FileEditor (see below). Added sensors are “humidity”, “temperature”, “tvoc”.
_SENSOR_DESCRIPTIONS = (
SensorEntityDescription(“smoke_level”, icon=“mdi:smoke”, name=“Smoke Level”),
SensorEntityDescription(“co_level”, icon=“mdi:molecule-co”, name=“CO Level”),
SensorEntityDescription(“humidity”, icon=“mdi:molecule-co”, name=“Humidity”),
SensorEntityDescription(“temperature”, icon=“mdi:molecule-co”, name=“Temperature”),
SensorEntityDescription(“tvoc”, icon=“mdi:molecule-co”, name=“VOCs”),
“battery_state”, icon=“mdi:battery-alert”, name=“Battery State”
SensorEntityDescription(“last_seen”, icon=“mdi:home-clock”, name=“Last Seen”),
“last_test_time”, icon=“mdi:home-clock”, name=“Last Test Time”
note: formatting not correct
I was able to determine the other values based on this screenshot:
I will start taking a look at templating regex (I remember seeing this some of my searches but wasn’t sure if that was the right path.
Appreciate your help!
